Electrical Help Needed for Hayward Super Pump Dual Speed
Need help with Electrical Diagrams on how to wire a new Hayward Super Pump 1.5HP 230V with Hi-Lo Switch Attached.
It's replacing an existing Dual Speed Hayward Super Pump 230V.
The pump is attached to Intermatic Timers (T106 + T103R - and has 4 wires from the box to the pump, (Black, Blue, Red and Green).
I would like to know what I need to do to bypass the hi-lo switch on the back of the pump and just keep utilizing the Intermatic Timer for the hi/lo speed options.
The Switch on the Pump has Yellow, Black and White Wires. Black is going to terminal 4, Yellow is going to terminal 2, not sure where white it going.
Any help on wiring would be appreciated.
Re: Electrical Help Needed for Hayward Super Pump Dual Speed
1. Colors don't matter . . . because you cannot, and MUST NOT trust them. Even electricians code incorrectly, AND there is not a standard color code for the power wires on multi-speed (multiple winding) motors.
2. Have you checked to verify that the internal wiring on the NEW pump is actually different (apart from the switch) from the OLD pump? You'll need to download motor manuals for both, to be sure.
3. Post (or link) pictures of the motors & motor name plate PLUS pictures of the wiring terminals in both the T106 + T103R.
