Jandy pump noise, debris or bearing? Video attached
So I cleaned my pool the other day and I think some of the debris went through to the pump for the last two days my motor has been making a noise I have attached these two videos.
Steps taken:
+ Try to clean the impeller with a wet dry vac
Note that the noises coming from the motor side and not from the impeller sidehttps://www.youtube.com/watch?v=M_j01X9Ifyw
https://www.youtube.com/watch?v=1Ksdfd2_a9k
pool/motor put in when home was constructed 2014.
Thank you for your help
Re: Jandy pump noise, debris or bearing? Video attached
Sorry.
I've never heard a pump make a noise like that. It does sound like something is striking something else.
How does the sound change when you turn the pump off? Can you localize it better then?
Regarding fouled impellers, my experience has been that, if I couldn't reach through the port behind the basket, and drag the debris out with my fingers, that the pump had to be disassembled to clean it.
Good luck!
Upgraded membership and moved thread to the IG pool repair section. You may need to log out and back in to see everything.
First of all thank you PoolDoc.
For someone in the future with the same issue:
I was able to figure it out, basically dissembled the rear ventilation fan (approx 6 screws) and voila dried old leaf was stuck to one of the fan blades. Heres the pic.
https://i.imgur.com/XbbKKGS.jpg
https://i.imgur.com/eNrOAIf.jpg
Amazing!
That's a heck of a sturdy leaf!
