cloudy water day 5
hello pool forum , Im a first year pool owner and at first I thought it was going to be easy. Now Im on day 5 cloudy water not sure how it happened because I regularly check levels . I use both strips and liquid test method and its perfect. I've used clarifier twice in a 48 hour period to little help. Just wandering where I go from here.
Re: cloudy water day 5
Post your ACTUAL test results.
If your water is cloudy . . . either your results aren't actually perfect OR you have bogus test kits (common!) OR your filter is not working properly . . . OR a few other possibilities.
So, ALSO include testkit make/model info, pump & filter make/model . . . and recent dosing history (did you add a bunch of calcium, clarifier, or 'floc'?)
Upgraded membership and moved thread to the pool water problem section. You may need to log out and back in to see everything.
