How much liquid chlorine usage is "typical" for folks in the hot and humid southeast in the summer months.
There's no general answer to that.
- The PRIMARY, NORMAL loss of chlorine is due to sunlight, so loss is a function of hours of sun vs pool surface area: big pools lose more! Also, having correct stabilizer and chlorine levels matters a LOT. Your stabilizer should be 30 - 80 ppm (higher levels can be compensate for) and your clear water (no current problems) chlorine level should be 5% of the stabilizer level.
- The BIGGEST loss is from runaway algae, and can be 20 ppm per day or even higher.
- A LARGE loss of chlorine results from 'people goo' -- sweat, spit, snot, pee, poop -- with urine typically consuming a LOT of chlorine.
Also, pool store chlorine can be 'stale' so that a bottle of "10% chlorine" may REALLY be 5% or even lower. Here's a better option for many people; Pool-Essentials-Chlorinating-Liquid carried by many Walmart stores. (MOST pool chemicals by Walmart are NOT recommended; this is an exception, and their bleach is likely to be 'fresher' than a pool store's).
All that said, IF you do everything right, via the BBB method, THEN daily chlorine consumption will typically range from 1 - 3 ppm, depending on how much people USE the pool.
My daily chlorine losses run from 1-3ppm, depending on the season.
