Re: Titan DE Filter problems
Thank you very much indeed for the thoughtful reply. I think I’ll take a better look at those grids and see what’s up. Really appreciate the kind response. If it’s a helpful addition to the forum, I’ll post what ends up being a solution. Best, John
Progress! Turns out the lack of strong stream from the pressure relief valve was due to debris in that line. As for the grids, I just replaced them. I did not see tears on the old ones, but they could be obstructed. When I opened the filter this time, I saw good adhering of DE except for the bottom 5 inches or so. Don’t think it’s because of not enough DE when loading, because there was a pile of it at the bottom of the tank. And I use a scoop and know the manufacturers recommended load.
I’ll see what happens when I get it going again tomorrow.
Pool water remains clear.
