Hello..I have a Super pump 1600 1hp that I've replaced the seals, housing plate and seal plate. It will prime up but when it gets pressure on it water begins squirting from several places where the housing and the seal plate join. Water also leaks from the channel at the bottom of the seal plate. I'm pretty sure that I've installed it correctly (famous last words), several times. Any thoughts? Thanks in advance
