Re: Should have Known Better
I'd say dump the pool guy, unless he is a family friend or something, first.
You have unfortunately added a bunch of copper to your pool, that is what is in most "Blue" products, which is a weak sanitizer of algae, no effect on bacteria. It sounds like you already understand that is what is staining your liner.
In regards to the numbers you posted, did you use your Taylor kit to get these? I don't know what "H" of 6.9 is. I have no idea how you get a measurement of 9 ppm for pristine blue, I assume you are testing for chlorine levels, or copper? What I don't see is a chlorine or FC number, or CYA.
Your options are 1: live with the copper in your pool and go back to BBB method 2: sequester the copper using another chemical and go back to BBB method 3: drain and refill and go back to BBB method.
With what sounds like a brand new liner that the pool store guy put in(?), if its his fault and the liner is damaged, have him fix it and pay for the drain and refill. Then go back to BBB method.
As far as going back to the BB method, read the sticky "Super Simple Pool Chemistry: or "Beginners guide to pool care".
PH 6.9 and FC or TC was 0 and the Pristine Blue or cooper level is now.3
I don't know what a desirable level of copper is, probably when you stop getting stains on your liner. Are you going to keep diluting or drain and refill.
You won't see a free chlorine number as most of the product is copper sulphate and a persulphate mix (MPS) so no CYA is required.
Any chance of a picture? I played around with ionisers for a few years ( 6-7) by way of investigation of something I saw heavily criticised in the industry and got a right ear bashing from Waterbear. I did have regular lab tests done on water sample and I was surprised that the results were as good as they were.
I used to run the pool at around 0.6ppm copper (there was also silver present) but what I learned is the ionised version of copper may measure 0.6ppm but there was a total copper level to and by the end that was up to 4ppm but no staining and no cases of green hair, throughout the experiment the pH was always towards 7.0-7.2.
What has always intrigued me is why some owners report staining issues very early on in the usage but that has always as far as I can be reasonably sure from copper sulphate based products and not from ionised versions.
I had quite a few discussions with Chemgeek over the years and when all is said and done there is a risk using copper based products that effects some pools and the extra cost of ionisers in my case or Pristine blue just doesn't seem worth it.
As to the release agent coming out of the liner, well that's a new one on me.
