Jandy PL700 Flow issue
I have a Jandy AquaPure PL700 salt water Chlorination System and having issues with the Flow indication, the flow sensor I have is a Zodiac Pro F13TSALD5469, this was a replacement unit that was install about 2 to 3 years ago. The flow light on the sensor card continues to blink and the Cell seems to stay on reversing. The temperature and chlorine reading are good (verified with temperature gauge in the pool (reads 90 degrees) and a salt water test strip reading about 3.0). Is it possible to bypass the flow sensor and what are the wiring configuration as it stands now I would not know which pins represent what measurement. -- Thank you
