What brand name pump for Vinyl 15' pool + LAWS
Hello, new to the forum, second year with a pool, lots of lessons learned. I have a brand new 15' genfoam pool (Walmart Intex vinyl type), 42" deep (water level about 32"). I think it's around 2000 plus change gallons. I am using an 800GPH, think it's 1/8HP or 1/16HP motor which is what was packaged with this pool. I am not getting much flow due to the small size motor and based on last year's experience, I will be cleaning every day (some leaves, kids' long hair, etc.)
What size is recommended for this type of pool? I have 1 1/4" connections on the pool wall. The pool supply store recommened a beefy 1/2hp filter for $250, the pool costs much less. I am willing to spend $100 and have found the following.
http://www.qualityinflatables.com/56633.html#2182
<Intex 2500 GPH, 1/2hp, 1 1/2" connections (will need adapters)>
http://www.qualityinflatables.com/bw58088.html#2322
<Bestway flowclear 2000 GPH, 1/2HP, 1 1/4" connections>
Aqua Leisure pump on eBay, 2150GPH, 1/4HP...
Should I go for higher HP?
Brand name reliability? Any other brands, Hayward is up there in price?
any other online sites someone can recommend? Are the first two reputable?
Thanks,
Sunny
Re: What brand name pump for Vinyl 15' pool
Hi, either one of those units would be a step in the right direction for you. A 1/2 hp should be very adequate for that pool.
Dennis
You should be able to run a 15' donut with a 1/6 hp pump--I did for 3 years. You must be careful that it seals and that you keep the filters either clean or new.
If you must go with a bigger pump, look for a 1/2 hp UPrated pump, not full-rated. You want the smallest least powerful pump so it doesn't rip the fitting out of the pool wall.
