New Member. Starting to clean up an uncovered GREEN pool.
Hi all, I stumbled across this forum while researching how to clean up my pool. We just moved here and the pool was left uncovered. I've been reading through the forum posts especially the sticky threads. Some great info here.
I have one question about getting started.
Is there a specific sequence that I should use to line the chemicals out. For example, should I get the pH right before getting the CYA correct, then shock it, or do I just try and balance everything (pH, CYA, TA, CH, FC, etc...) all at once?
Thanks for letting me join the forum,
Rand
