I just purchased the K-2006C kit as recommended on this site. Do I also need to get the K-1000 OTO or will the K-2006C have everything that I need?
The K-2006C has everything you need. The only reason for the K-1000 OTO would be if you wanted a different kind of chlorine test that cannot bleach out, but the FAS-DPD test in the K-2006 is very reliable and you can always add more DPD powder if you see a flash of pink that doesn't stick red due to a high FC level.
The k-2006c has what you need. You do not need the k-1000.
Hey jpo, I'm new here (today) and thought I'd chime in. Not really sure how active this forum is, being as that you posted your question eons ago...okay 6 weeks. That kit will do you right. Having the K-1000 would be redundant, unless there is a reason why you would want to test for chlorine using the OT method. (er read this DPD vs OTO )
Take note that with the cya test, you will only get 2 test from one of those bottles. Don't know about you, but I really don't place 100% reliance in anyone elses testing of my pool water. However, for warranty purposes (Premix freestone, etc...) and since it is 'free' I will have Chemical pools and Pinch a penny test for me. If their test results suggest that I do something, I'll test using my Taylor kit K2005. Again, if the third party test say my cya is too low, I will use my kit to confirm.
I do test regularly for Cl and pH, too often if you ask my wife. ;)
The kit you have will test for Cl in a wider range than the K-2005. The Cl test is a bit more expensive and time consuming.
PUTTING FAS-DPD TO THE TEST:
THE LATEST TREND IN CHLORINE ANALYSIS
