Re: Too much clarifier/floc?
I am not sure about the clarifier problem. I do know that, according to the manufacturer, the slimebag is not to be used with clarifier. I assume it clogs the bag. This is probably why the seam blew out.
EricF
Thanks Eric, but I was thinking that if I overshot on the clarifier, what I have is dispersed fine particles, which is what the Slime Bag is for. In defense of the Bag, I have used it for several years, and it has been exposed to high levels of chlorine so I have no complaint about the seam. It worked well. Having no other answers posted here so far, I am going to keep on doing what I am doing, but add a pair of old pantyhose to the skimmer basket, put the Bag back on the return, keep chlorine at at least 5 ppm, and filter, filter, filter.
Throw on some skimmer socks! There is recent long discussion about using them. They filter an amazing amount of suspended stuff and will help cut down on your backwashing needs. In your extreme situation, if you have 2 skimmers, you might just put a sock on one (that way, if it clogs up due to the sock, you are still skimming with the other).
I would buy a five pack and just keep rotating on a new one and wash out the old. Every little bit helps!
Thanks, TP, I will do that. I did find that discussion and thought I would give the pantyhose a try first but they ended up coming off the filter basket and got sucked into the pump basket so I don't know just how much dirt they caught before they got "washed"! so will look for those socks. Walmart?
Don't know about Walmart. Leslies has them (local stores and online). I would guess any pool store has them. I take out the "lifting stick", put in the skimmer sock then put the stick back into the skimmer. This helps lock the sock in place, but I've never had one come out yet.
I think these are better than nylons, they have a pretty dense and soft mesh that really seems to grab onto pollen and fine dirt.
