PS233 test kit and CYA test question
I am using the PS233 kit for the first time and I want to be sure that I am doing the CYA test correctly.
The instructions say to use the #9194 dispensing bottle. I assume that is the small bottle with the squirt top since it is marked "pool water fill line" and CYA reagent fill line". There are no part numbers on the containers/bottles.
In step one, the instructions say to fill the bottle to the 15ml mark with R-0013, but the bottle has no such mark. None of the measured containers have a 15ml mark.
Step two says to fill the bottle to the neck (just below cap threads) with pool water.
On my bottle the first line is "pool water fill line" and next line up is "CYA reagent fill line", so I filled the bottle with pool water to the first line than added the reagent to the second (higher) line. I then put this mixture into the CA view tube. .
It would seem that I am doing the opposite of the instructions as I am adding pool water first (possibly first mark is 15ml) than topping off with the R-0013 Reagent. The way I am doing the test shows no CYA in the water at all.
However, this may be expected since this is a new gunite pool and no chemicals have been added yet. I'll ask about my specific readings on a separate post. Am I doing the test correctly?
Thanks.
Is it 1/3 CYA reagent and 2/3 pool water? Ben, are you there?
I'm still confused. Not about whether to add the water or reagent first but as to how much of each.
The first line on the bottle says "pool water fill line". That would mean add 15ml of pool water first.
The second line says "CYA reagent fill line". That would mean add 30ml of reagent.
Is this correct? The instructions on the test kit lid says "add 15ml of CYA Reagent ..." then fill to top with pool water".
One method is 1/3 water. The other way is 1/3 reagent. Which is it?
Sorry if I'm dense on this - I want to make sure I understand correctly.
Re: PS233 test kit and CYA test question
sorry to beat this dead horse, but the directions on the box of the ps223 are wrong? this confused me too.
It does say
fill R013 reagent to 15ml mark----first line in the bottle.
"Step two says to fill the bottle to the neck (just below cap threads) with pool water."
It makes no mention of the 2nd line that says fill with pool water.
So do I follow the box or what i'm reading here and dothe 1/2-1/2?
fill to the second fill line.
