Re: Durazzo vs Pebble Sheen
Durazzo and Pebble Sheen are both good products made by large well known companies. Durazzo (www.sgm.cc) is a good product but does not have a large color selection. Check out Hydrazzo (www.aquavations.com) for a larger color selection. The Pebble Sheen made by Pebble Tec (www.pebbletec.com) has a good color selection. The polished marble based finishes will be smoother than the polished pebble based finishes but the pebble based finishes will be more chemical resistant. All plaster pool finishes will give you years of enjoyment if you keep up your chemistry. Personally I like the look of the pebble finishes but all pools look great if you keep your chemistry balanced and have good filtration.
