New pool owner in Norway- PH/Alc questions
Hi, I am a new pool owner, with a small glassfiber pool of 3x6meters(23000liters/6000 gallons).
Recently I noticed some yellow/brown stains that I thought might be rust deposits(I am on city water, but might have gotten some earth blown into my pool, as I am remodeling the area).
I did some testing of my water, and found that my Alc was at 40 and my PH was at 7, so I thought the low Alc might cause that water to deposit easier, and wanted to bring it up. I added 1kg of SodiumBicarbonate and one day later my Alc was at 70 as I suspected with that ammount, but my PH was at 7,6, so I was a bit hesistant to add more in fear of rising the ph even more.
I retested my water this morning before posting and this is my numbers now:
PH: 7,8 (bordering on 8)
Alc: 60 (Bordering on 70)
Cal: 50
Cya: 30 (Bordering on 40)
What I am wondering is if I should continue to add SodiumBicarbonate until I get my alc to where I want it(I was thinking of 100-120), or should I lower the ph before I continue to raise the Alc. I tink I read somewhere that the SodiumBicarbonate won't raise the ph higher than 8, so in my mind it sounds like I can add enough of that to get my Alc to 120, and then use some of my ph-down to lower my ph to 7.6 or thereabouts.
My ph lowerer says it contains Troclosene, sodium dihydrate 50-100g/100g is that ok?
My pool will soon have a heater connected too, so I think to get my alc up would be a good idea.
Thank you for all advice, this seems like a great comunity.
Lonestar
Re: New pool owner in Norway- PH/Alc questions
You did not tell us your Free Chlorine or Combined Chloramine levels. You may well have an algae bloom. Either that or some sort of metals in your water. Try putting some Ascorbic Acid (Vitamin C) on the stain and see if it fades it. If it does, it is metal and our metal removal experts can advise you.
In my opinion, your approach will not work because it is not getting at either problem, algae or metals, and you should leave your pH and Alkalinity alone.
Thank you for your answer, sorry I didn't mention the Clorine levels, here they are:
My Free Clorine have been a bit up and down, I was steady inbetween 1 and 3 earlier, but then I tried a floater called "EasyPool Maxi" that should have chlorine, stabilizers and floculation, but I think what I did wrong was to keep it in my pool with my cover on, and the pump running 24/7 and suddenly my Free Chlorine was at 7,6. I have let it stay out of the pool for a while now, and I am now at 1,6. My Combined chlorine is at 0 (I get a faint faint purple tint on the combined chlorine test that goes away with one drop, so I might have a tiny bit), so I don't think it is an Algae atack, and the water looks sparkly clean and has only been in the pool for about 1 month.
I was going to do the Ascorbic acid test, but I forgot to get the Vitamin C at the store, will do that.
The PH/Alc I wanted to have adjusted to acceptable levels before I connect my heating pump, so I won't corrode the metals in that one.
Lonestar
OK. That helps. With your CYA at 30, you need to keep your Free Chlorine between 3 and 6, but if it hits 7 or 8, it's not a problem. Period. But don't let it go below 3. The tiny bit of Combined Chloramine isn't a problem.
Have you tried brushing the pool as well?
Thank you, I put in my "EasyPool Maxi" earlier today, and I will let it stay in and see if it goes up to your recommended levels, like it did earlier.
I have tried brushing(with my pool brush) on the yellow/brown spots and they didn't disappear, but I will come back to them when I have tried the Vitamin C pills on them.
Good Luck! I'm going on vacation tomorrow so hopefully one of the other team members will follow up.
I bought some Vitamin C tablets (They were Effervescent tablets) and it didn't seem to take away the yellow/brown stains, but yesterday I did a discovery, I found some small metal shavings that were right on top of the small spot, I confronted my contractor about this, and it seems that when they have set up the decking they have drilled into the edge of the pool, and it is made of metal, and the metal shavings have fallen down in the pool and made lots of tiny spots. I can't seem to get rid of the spots, but will I be able to polish them away when I drain my pool, since it is made of glassfiber? Should I drain my pool (since it is not that big) and do a good and thorough backwash of the sandfilter, or will I be fine leaving it in, and fixing it when summer is over (not a really long summer here in Norway anyways ).
I also see that since I am a Trial User I can not see my own profile, or other settings, I have filled out the form and posted a post, shouldn't this help with my User Rights?
Sincerely
Lonestar
