3 Return from Pool Filter - What do they do?
Due to a recent storm in the area, a felled tree knocked over a potted plant which crashed into the PVC piping for the filter and pump. While replacing the piping, I noticed that of the three valves, two were closed and one was partially open.
As I'm new to taking care of my pool by myself, I was wondering where the pipes go to, and what the valves are there for.
For the record, there are four pipes coming from the ground. One must be from the pool and leads to the pump, and then there is a pipe from the pump to the filter. Then there is another pipe from the filter to the three pipes in the ground. I'm assuming there is only one intake pipe, and that is the one leading to the pump. The other three must be for output. I'm also assuming that one pipe is for the aerator for the pool (maybe the thinnest one that is closed off by the valve) and the largest one that is partially open must be going back to the pool. Any idea what the other one is for? There are no water features for the pool. Could this possible be waste and lead to the sewer? The diameter of the PVC is from left to right in the picture, 3/4'' PVC, 1 1/4'' PVC, and 1 1/2" PVC, all leading to 1 1/2'' PVC that connects them to the filter.
<a target="_blank" href="http://imageshack.us/photo/my-images/819/3tji.jpg/"><img src="http://imagizer.imageshack.us/v2/150x100q90/819/3tji.jpg" border="0"></a>
Re: 3 Return from Pool Filter - What do they do?
Your pictures didn't appear correctly. Use this button to link them to this thread: http://www.poolforum.com/pf2/images/...nsertimage.png
Also, for me there is no button after your sentence "Use this button to link them to this thread:" for me, in either Chrome or IE. Hope the way I chose to post the pictures is sufficient.
For future reference, after you click on the 'reply' button in the lower right, that button will appear in the upper left corner where all the other buttons are such as B for bold, U for underlining, A for changing font color, etc. One of the buttons will look like that little picture I showed you in my last post.
Your picture is there, just small.
[IMG]<a target="_blank" href="http://imageshack.us/photo/my-images/819/3tji.jpg/"><img src="http://imagizer.imageshack.us/v2/280x200q90/819/3tji.jpg" border="0"></a>[/IMG]
wrswldo
كشف تسربات المياه
شركة تخزين اثاث بالرياض
شركة نقل اثاث بالرياض
شركة تنظيف فلل بالرياض
شركة تخزين عفش بالرياض
شركة نقل عفش بالرياض
شركة تنظيف واجهات حجر بالرياض
شركة نظافة بالرياض
شركة تنظيف شقق بالرياض
شركة جلي بلاط بالرياض
شركة تنظيف مسابح بالرياض
شركة تنظيف خزانات بالرياض
شركة عزل خزانات بالرياض
شركة تسليك مجارى بالرياض
شركة تنظيف موكيت بالرياض
شركة تنظيف منازل بالرياض
شركة تنظيف واجهات زجاج بالرياض
شركة تنظيف مجالس بالرياض
شركة تنظيف بيوت الشعر بالرياض
شركة تنظيف بالرياض
عزل الاسطح
شركة تنظيف بيارات بالرياض
شركة رش مبيدات بالرياض
شركة مكافحة حشرات بالرياض
شركة تنظيف مساجد بالرياض
شركة تنظيف قصور بالرياض
شركة صيانة خزانات بالرياض
شركة دهانات عامة بالرياض
شركة مكافحة الفئران بالرياض
شركة مكافحة النمل الابيض بالرياض
شركات مكافحة البق في الرياض
كشف تسربات المياه
شركة شراء اثاث مستعمل بالرياض
شركة تنظيف عمائر بالرياض
شركة نظافة بالرياض
شركة تنظيف بيوت بالرياض
ترميم المنازل
شركة شفط بيارات بالرياض
شركة تنظيف بالرياض
شركة تنظيف مدارس بالرياض
شركة عزل اسطح بالرياض
اصلاح تسربات المياه
مؤسسة نظافة بالرياض
شركة نقل وتغليف عفش بالرياض
مستودعات لتخزين وحفظ الأثاث بالرياض
مكافحة صراصير المنزل
مكافحة صراصير المطبخ
حل ارتفاع فاتورة المياه
شركات العزل الحراري
شركات عزل مائي
شركة تنظيف الاثاث بالرياض
تنظيف انتريهات
شركات تنظيف الستائر بالرياض
شركة تنظيف كنب بالرياض
مكافحة صراصير الخشب
شركة مكافحة الصراصير بالرياض
ارخص شركة نقل اثاث بالرياض
شركات مكافحة القوارض بالرياض
اسعار نقل العفش بالرياض
كشف تسرب المياه الكترونيا
شركة تسليك مجاري الحمام بالرياض
مكافحة حشرات الفراش بالرياض
كشف تسربات المياه بدون تكسير
دهانات غرف نوم
ديكورات غرف نوم
I appreciate any advice to get my water chemistry accurate without breaking the bank. Also, how do I complete my registration so I can see the forum and do searches, etc. I don't mind sharing my address if thats what it takes. Thanks again, Cindy
WM: If you click on the pic, then download the image, you can see it full size.
wrswldo:
Here's what I think I'm seeing.
1) the pipe (2"?) leading from the ground to the pump is certainly coming from the drains and skimmer.
2) the other 3 pipes are some sort of return pipes, each of which can be shut off by the bronze valves. This would be a good time to replace all three with PVC ball valves.
3) Clearly the broken white manifold went to the 3 returns, with a reducer going to the one with the red valve. This needs to be rebuilt but with PVC, schedule 40 fittings, and primer and glue, it's a very easy job. Dry fit it all before gluing. Personally, I'd also plumb in quick-connect unions between each valve and the manifold to make for easy maintenance.
4) Looks like the black piece next to the manifold was to connect the manifold to the return on the filter (the one not connected). Look like the "L" between the pump and filter was part of the connection. Don't reuse this stuff. New 1.5" PVC and Schedule 40 fittings are inexpensive. You CAN reconnect to the piece coming out of the filter.
5) The hose coming out of the OTHER side of the filter, between the multivalve and the cinder block wall, is the back wash hose. It is not clear where it goes.
I really don't know where the 3 returns go. You could hook a shop vac to each and see where the air comes out. When you said "aerator" I don't know what you mean. Aeration is only used in pools to raise pH, or is inadvertent.
Hope this all helps.
