Considering an SWCG and a VS pump
Hello everyone,
We just bought a house that has a 15,500 in-ground pool with a screen enclosure and a DE filter. This is our first pool and I've been trying to learn as much as possible. So far this forum has been very helpful. My chlorinator is not working and I have decided to replace it with a SWCG. My electric bill was very high the first month and I'm sure it is due to my pool pump. I was probably running it excessively 12 hours a day so I cut that to 9 hours but I have decided to replace it with a energy efficient model. Any suggestions for best value SWGC and energy efficient pump would be appreciated. I'm thinking about a pentair intellichlor with an intelliflo VS pump...
Thanks in advance
Re: Considering an SWCG and a VS pump
Thank you for the input. I visited 3 local stores yesterday and they all recommended different SWCG. Two of them recommended the Pentair VS pump but one recommended a Waterway pump. His reasoning was that the pump and the drive (I think) are separate on the Waterway so if one fails you don't have to replace both as you do with the Pentair...
Better check the price on the Waterworks electronics module -- replacing it separately is not of much value if the electronics part is, say, 60% of the entire unit.
I should say that I don't know about this pump, one way or the other. But I do know that some of their filter designs are very marginal. And my experience is that a company goes for 'show' and not function in one part of their product line, tends to do so in other dimensions as well. So, look carefully at the WET end of the pump. Poor design or manufacturing there can make efficiency on the dry end sort of worthless.
Frankly, you can achieve very, very high efficiencies on your pool, by purchasing a 3/4 HP 2 speed Whisperflo with a toggle switch, and running it on low (~500 watts) for 4 - 8 hours per day. In many areas of the country, that translates into $6 - $10 per month. And, you'll have a VERY reliable pump.Pentair Whisperflo WFDS-3
Just remember that the Whisperflo has an abbreviated warranty if you purchase it directly using the Amazon link above or another online source, so if you do buy it directly, be prepared to install it promptly on receipt. Most failures will occur within a week or so (not that I've ever had either a Pentair or Hayward fail prematurely -- discounting the time when I wired one incorrectly!), so if you install promptly, you can still return it within Amazon's 30 day window.
Ben
