Received PS234 kit today and here are numbers
FC = 12.5 Lowered dial down on SWG ( now at 20 was on 40)
CC = .5
TC = 13
PH = 7.2 Trying to lower TA
TA = 140
CAL = 200
CYA = Was below 100 line ( about an 1/8 of an inch)
Salt = 3200
Temp = 88
What do you all think I should do since I am new to this. And thanks Ben for sending the kit :)
Re: Received PS234 kit today and here are numbers
I'd grab a cold one and go swimming!:D
Seriously, I don't think I'd worry about the TA being 20ppm too high. Chances are with the SWG/SWC the PH will climb back up anyway. Keep your FC up since your CYA is so high and enjoy!
Thanks for info. I was at 180 for TA and thats why I lowered ph from what I read in forums to do.
With a SWG and the CYA near 100 you should probably run your FC at around 3-5 ppm. If you are not getting CC with this setting it's working.
