Too Much Chlorine in My Little Intex
Hi all. Glad to have found the forum here. I set up my first pool ever (8' intex vinyl), and after having my tap water tested the first day I had the following:
FC 1.5
TC 1.5
CH 150
CYA 0
TA 150
PH 7.7
Phos 300
At that time I purchased a Chlorine and PH test kit from Leslie
I added 1.4 oz of Muriatic acid last night to work on the TA
Retested today and had TC levels near 0 according to my kit, and PH at 7.5
I decided to add chlorine and used poolcaclulator to figure out the amount, however when I put my new stats in I neglected to change the pool size from 10000 gal to 640 gal.
I added 18 oz of bleach (way too much) instead of 2 oz.
now my chlorine levels are 10+
How long will I need to wait for levels to drop down naturally to safe levels, or am I just better draining partially/full and starting over.
Thanks a ton!
Re: Too Much Chlorine in My Little Intex
With no CYA in the water, it won't be long. Don't worry.
An easy way to start up a freshly filled pool is with our Super Simple Start-up Recipe. Read about it here:> http://pool9.net/ssr/
Welcome to the Pool Forum!
(Until you registration is completed, you won't be able to see the rest of the forum while you are logged in. So, copy that link and then paste it into a browser window after you log out.)
. . . membership updated.
To be a little more specific -- just a few hours of full sun will take your chlorine back down to zero.
