Re: Green Pool - Please Help
I assume these readings are from the pool store? Unfortunately, pool stores are notorious for inaccurate testing. It would be better for you to test it yourself.
The test kit that we think is by far the best is the Taylor K2006 or 2006C (better buy). Not available locally but you can get it through this link that takes you to Amazon: http://pool9.net/tk/ (Since you have a CYA reading of 70, you're going to need that K2006 kit. Other kits can only read chlorine levels to 5ppm and you'll have to run higher than that to compensate for that CYA reading. You can read more about the connection between CYA and chlorine here:> http://pool9.net/cl-cya/)
But, in the meantime, go to Walmart and see if they have the HTH 6-Way drops-based kit (no test strips!) and get that. If they don't, get an OTO/Phenol Red kit (yellow and red drops) instead. Use it to test and then post your numbers. Also while you are at WallyWorld, get several jugs of their generic 8.25% bleach, several boxes of 20 Mule Team Borax (laundry aisle) and a gallon of distilled water.
Test your water and post your numbers. Also tell us about your pool. What kind it is and volume. What size of pump (hp) and what kind and size of filter.
The most critical thing, assuming that pH reading is correct, is that any pH readings below 7.0 are acidic and can damage your pool. You need to get the pH up ASAP. You can use the borax to raise the pH. I can't really suggest an amount without knowing your volume.
Welcome to the Pool Forum!
(Until you registration is completed, you won't be able to see the rest of the forum while you are logged in. So, copy the link and then paste it into a browser window after you log out.)
. . . membership upgraded.
Get a cheap OTO/phenol red drops kit and 20 gallons of PLAIN 8% bleach per 10k gal of pool water and a gallon of distilled (NOT: spring, bottled, artesian, etc => distilled) water. You should be able to get all these at Walmart.
1. Retest pH using 1/2 pool water and 1/2 distilled water. If the pH is between 7 & 8, leave it, the calcium, and the alkalinity levels alone for now. If the pH is less than 7 or more than 8, post the results you got AND tell us what sort of pool you have.
2. Make sure your filter is ON 24/7. If you have a DE filter, put it on bypass or recirculate.
3. Unless you have a DE filter, odds are against you having 'pretty' water by July 4th. Not impossible, but not likely either.
4. Till the algae is dead, there are ONLY TWO things you should focus on: (1) maintaining a pH level that won't hurt your pool and (2) killing the algae. Forget about everything else.
5. You NEED the K2006 Mom mentioned. If your CYA level is really 70 ppm, you may need as much as 35 ppm of chlorine to kill the algae. You can only measure and control those levels with a K2006 (or kits that are even more expensive!)
Concrete or vinyl pool?
If it's concrete,
+ adding bleach at the rate of 4 gallons every 2 hours.
+ continue till the algae turns gray / brown OR until you reach an ORANGE (off-scale) OTO test result.
If it's vinyl
+ adding bleach at the rate of 2 gallons every 2 hours.
+ continue till the algae turns gray / brown OR until you reach an orange-tinted yellow (off-scale) OTO test result.
