Filled small 10ftx30in Intex pool with well water-now it's yellow green
Hi- Bought this pool on sale, on a whim, summer fun for the kids. We filled it in a couple hours with the hose using our well water. It started to look cloudy and yellow while filling it so we added a quart of household bleach although it's still cloudy and greenish-yellow. We have heavy iron around here and I'm guessing we're in for a bit more work than we bargained for testing and buying chemicals. Yeah, I suppose I should have researched a bit more
Since the pool is so small, what's the best way to correct this problem without too much effort?
Thanks!
Re: Filled small 10ftx30in Intext pool with well water-now it's yellow green
Do you have a way to fill with water that is not from your well? If so, the fastest way will be to dump and refill. It is really hard to deal with a metals-contaminated pool and these little Intex pools are even harder to clean up than a bigger pool.
Welcome to the Pool Forum!
Thanks for the quick reply! Unfortunately, we don't have another way to fill it. I'm not sure how we could get our household (softened) water attached to a hose outside? Or even if we could get little trucked in.
So, it sounds like this is a futile effort huh? Is it at least safe to swim in?
If your chlorine is between 1 - 5 and your pH is between 7 & 8, it's safe for swimming.
You can connect a water hose to the COLD WATER side of your washing machine hookup, and fill the pool that way. If you reconnect your WM hose with this:Gilmour Brass 2-Way Connector
then you'll be able to easily refill your pool later.
You can get a WYE like that at Lowes, but try to get a better brand. They all will be Chinese made, but a US brand like Gilmour will try to enforce quality control, and you do NOT want a junk valve leaking water inside your house. Do NOT get a plastic valve; ONLY brass.
. . . thread moved into correct section; membership updated.
Re: Filled small 10ftx30in Intex pool with well water-now it's yellow green
Hooking hose up to the WM connection is the perfect solution. Draining it now, refilling tomorrow! Thank you for the help Pool Forum Pro's!
