Re: HELP Cant See the Bottom
7Iron
I have a 5k gal above ground with large cartridge filter and 2 stage pump (1hp & 2hp).
Do you mean a 2-SPEED pump? If so, put it on low.
I read through your chemical list:
added metal free . . . adjust my alkalinity with sodium bicarbonate . . . 1/2# chlor bright (sodium diclolor s tra dih 99%) . . . . oxidized with 1 #pool breeze (potassium monopersulfate 44.7%) . . . 1# Fresh'N'Clear (potassium peroxymonosulfate 38%) ... added 1.5 lbs sodium carbonate.....4 oz Ultra Bright clarifier "blend of polymers" .... used the other half of the 1lb bag and put to 3" tabs in the skimmer...added 1.5 lbs sodium carbonate . . . add an algae control (poly[oxyenthylend(dimethylimino)ethylent(dimethyliminio )ethylene dichloride] ... add 2 lbs of sodium carbonate
You, my friend, have been "pool-stored". Badly.
Your pool is WORSE OFF, than it was before you started adding goop. (By the way, the poly. .. thing is just what we call polyquat. We occasionally recommend it.) I'm really surprised the tech at Natural Chemistry admitted that Metal Free does NOT remove the copper: it just *moves* it, from the stained areas to the water. If you didn't have stains . . . it did exactly NOTHING, except complicate things and waste money.
Cleaning up chemical hobo soup is never fun, because we're into various chemical interactions that are too complicated for even "Chem_Geek" to figure out. In other words, NOBODY knows what's happening in your pool.
Here's your best option:
1. Unless water is really expensive where every you are, drain your pool and refill. If you've got a soft-side pool like an Intex or a Summer Escapes, you could spend a month trying to clear your water, using their undersized filters.
2. Complete the pool equipment form, so I can have a better idea what you have to work with: http://pool9.net/pf-equip-form
3. Read the Super Simple recipe page: that's the easiest way to start up a 5k gal pool: http://pool9.net/ssr/
This looks like a duplicate of this thread at TFP where I had already responded. You need to pick ONE forum and stick with it, otherwise you're likely to get confused. Though the advice may be similar in some respects, it might diverge in others and worst of all might be conflicting at different points in time.
As I described in my post in the other thread, the METALfree product and the Polyquat algaecide are completely incompatible and produce a precipitated cloudy mess.
Ben's suggestion of water replacement is probably the fastest and surefire way to get the water clear. If your small pool only has one return, one skimmer, and no floor drain, then it may have terrible bottom circulation. Pointing the return diagonally downwards might help to move the cloudy material to the filter.
Ben, note that the cartridge filter is said to be "large". For the pool not to clear after 24/7 pumping for 4 days, there must either be some tears or bypassing of that cartridge filter (or blowing through it) or the circulation must be terrible in some areas of the pool. Usually the combination of the two polymers is an easily removed precipitate, not a colloid that can't be filtered.
FYI (from the other thread), the lower pump speed and maintaining a proper chlorine level seems to be doing the trick and the pool is clearing up. It's down to a 1 out of 10 where 0 is clear and 10 was the cloudy mess from the combined milky chemical precipitate of polymeric metal sequestrant with polymeric algicide/clarifier.
If he's posting there, I'll close the thread, here. There's no reason for two of them running.
Thanks, Chem_Geek.
