First timer with AG pool that won't clear up
First time homeowner with new pool and struggling to get the water looking correct. I have a Hayward sand filter. Pool is an above ground and I can not seem to get the pool to clear up. Local pool company had me put in 5 gallons of liquid chlorine. Any suggestions? The water is not green but yet just an aqua color. I was instructed not to vacuum as of yet. Please help!!!
Re: First timer with AG pool that won't clear up
Cflynn22
+ Putting in the chlorine was good. If there's still any green left, do it again.
+ If there are piles of algae on the floor, vacuum them to WASTE, and not back to the pool.
+ Get a cheap local OTO / phenol red drops kit. Check your pH BEFORE adding more bleach. If it's between 7 and 8, forget about it for now. Keep your chlorine DARK yellow (off scale) till the algae is gone (no green, just gray). You can't test pH when the chlorine is off scale, however. Skip chlorine doses if the color ever reaches orange. See http://pool9.net/oto/
+ If it's been more than a week without clearing you probably have the common oversized pump matched to an undersized filter. This causes 2 problems. First the high pressure drives the algae THROUGH the filter. Second, the high flow on backwash carries sand out of the filter, so you have less and less sand to filter with.
Find your pump and filter make and model numbers and I'll take a look after you complete this form: http://pool9.net/pf-equip-form/
The thread number needed on the form is "24488".
