Need to replace my filter and don't know what size, brand....
I have a Lomart 18'x33' and roughly 4' deep. The pool is probably ancient, but has worked very well. I need a new sand filter and need to know the proper size and pump size. I was looking at a 22" Hayward with a 2HP pump....
Re: Need to replace my filter and don't know what size, brand....
Hayward is currently a better choice then Pentair, because Pentair has decided to slash the warranty period on pool equipment not installed by a contractor. A 22" sand filter would be ideal . . . but you are only looking for a 40 GPM flow rate. Higher flow than that will cause filtration to deteriorate, and will wash sand out, during backwash.
That translates to a 1 HP pump OR LESS! I'm working on a selection chart for you, and should have a preliminary form of it ready this afternoon.
So grateful for your response!! Unfortunately I bought a Hayward, 21" with a 1 1/2 hp pump... Should I return it for a 1 horse?? The pool is so green. Never had it like this!! But without circulation I would not expect anything else... Buying chlorine (unscented bleach) in a few...
Well dang . I will see what I can do! And get the k2006 testing kit right?
