My lights are not in sync. I have two Colorlogic lights that function, but not in sync.
Any suggestions to reset?
Hi and welcome to the Pool Forum! I can't help you with your question but hopefully someone will be able to.
I believe you will need the "Hayward ColorLogic Network Module" if they are Colorlogic 4.0 lights.
You can contact Hayward directly to find out if there is a way to do it without the module (or if they are older lights):
Hayward Pool Products
(908) 355-7995 (U.S.) Mon-Fri, 8 AM – 5 PM
One Hayward Industrial Drive
Clemmons, NC 27102
Another thought, if you don't have a Pro Logic controller and/or don't want to spend the bucks on the network module. AND you are competent with wiring, you can probably get things pretty close by changing your switch to an DPDT switch. Levitton (the Lowes brand) makes such switches in a few colors.
. . . membership updated.
Thanks, Kelemvor!
