Gravel level with respect to laterals: TR140C Penair Sand Filter
I have just finished plumbing in a Penair TR140C Sand Filter and have put in 275#, per spec, of 1/4-1/8" pea gravel. The gravel, wet, is just above the laterals, perhaps a half an inch.
Is this the correct height, or should the laterals be exposed and by how much?
The sand will be next, once I am satisfied this is the correct gravel level.
Re: Gravel level with respect to laterals: TR140C Penair Sand Filter
I got an answer from Pentair, but in case others wonder about this I am providing their answer.
They said that the pea gravel is used to aid/protect the laterals. Having it just slightly above the tops of the laterals is fine. This required 275# of 1/8-1/4" pea gravel, exactly what the spec called for.
I have added pool filter sand above, 650# of it, which provided 13.5" of freeboard from the top inside of the unit to the top of the sand surface.
In this configuration the unit is working well, with a pressure of 12 psi and flow rate of 110 gpm.
Hopefully this information will be useful to another reader of this forum.
Thanks for coming back and sharing what you found out. That's what makes this forum work --- everyone helping out!
