Pool chemicals and running the pump
Hello all,
I have a general question about putting chemicals in the pool and then running the pump. Does running the pump have any effect on the chemicals I put in? In other words, if I put dichlor and borax into the pool and then run the pump, will it filter out the chemicals or help distribute them better?
Thanks!
Re: Pool chemicals and running the pump
You ONLY want to add chemicals when the pump is running. Your chemicals will not filter out.
