Please Help on Intex krystal clear saltwater system
Hi everyone
Hope everyone is enjoying their pool,
I am purchasing a summer escapes pro-frame 14' x 42 inch which holds approx 3300 gallons of water,
I want to purchase the intex krystal clear saltwater kit
Should i purchase the one rated for up to 7000 gallons or should i purchase the one rated up to 15000 gallons
Please help
Re: Please Help on Intex krystal clear saltwater system
Sorry this got overlooked.
Probably the larger one would be best -- just turn it down. AND . . . DISCONNECT the power to the copper electrodes! Those are a MESS.
(You do know that connecting Intex gear to Summer Escapes pools is often not straight-forward?)
PoolDoc/ Ben
Thank you so much for all the help, I actually purchased the big one and I went ahead and purchased the intex sand pump cause I'm going to scrape the summer escapes filter pump but keep the skimmer.
I understand this is not a direct fit, but it is not impossible from what I read so far. I am setting the pool some time next week, I am just waiting on some adapters and an additional hose.
Thank you so much Ben thru this process, any additional information always helps.
If you would, take pictures of the connection process. I know others would like to know what the obstacles and solutions are!
PoolDoc
I will take pictures and I will list part numbers as soon as I am up and running.
