Installing a 500W bulb in a 400W housing in Pentair Amerlite
I have a Pentair Amerlite that has a label stating the bulb it came with is a 120V 400W R40. It doesn't have a warning stating that a bulb exceeding the wattage listed should not be used, like most light sockets state the maximum wattage allowed.
The instruction manual shows the replacement parts and lists 300W, 400W and 500W options. The only place I see anything related to wattage is in the replacement instructions where it indicates you will need a new gasket and a lamp, for proper type and wattage, see table 1. Table 1 lists the 3 different wattages. It's as if the housing is the same in the diagram and just the bulb is different.
The pool store guy sold my wife a 500W bulb because they were out of the 400W ones and told her it should work, but I have my reservations.
Will a 500W bulb work in the 400W housing without overheating and tripping the overheat sensor or burning out prematurely?
I don't want to find out the hard way....
Re: Installing a 500W bulb in a 400W housing in Pentair Amerlite
I'm only guessing but I'd follow what the manufacturer says, not a pool store guy who was out of what you needed and wanted to make a sale.
. . . membership updated.
FYI if anyone else is looking for this specific answer: I was finally able to call Pentair customer support at 800-831-7133 for technical assistance on this question. The tech assured me that the housings for the Amerlite with the 300W, 400W and 500W bulbs are identical and that a 500W bulb can be used without issues. The original pool store guy and an employee from another pool store that I also asked who said it was OK were correct.
Good to know.
Thanks for posting the follow-up!
