Will lettering on foam panels under pool show through liner
Hello all
I am installing Ann above ground pool. I have started putting down foam board that has black lettering on it. In fact it has a lot of black lettering on it. I will be installing a 25 ga liner. Will the lettering of the foam board show through the liner once everything is installed?
Re: Will lettering on foam panels under pool show through liner
I wouldn't think so. I went back and looked at pics of my install when we replaced my pool two years ago. I did not have any lettering on the foam but they did use black tape of some type to tape the seams of the foam. It does not show through at all.
Thanks. I'm planning on installing the liner toward the end of the week or this weekend. I have been so careful with everything about this pool that I don't want to get it finished to just end up seeing lettering showing through the liner.
I don't blame you one bit! Have you ordered a good test kit so you'll have it when the pool is up and running? The best one is the Taylor K-2006 or 2006C (better buy) --- see test kit link in my signature below. Also, it might be helpful to read the Super Simple start up recipe in my signature also.
