Re: Bacqucil Home Test Kits
The Taylor K-1444 tests biguanide (Baquacil) levels and is reasonably priced. The Taylor K-8020 can be used to test hydrogen peroxide (oxidizer) levels. The pH, Calcium Hardness (CH) and Total Alkalinity you can get in a standard chlorine/bromine test kit such as the Taylor K-1005.
Hi and welcome to the Pool Forum!
We used to have lots of people coming here to the forum who used Baquacil but you are the first we've heard of in quite some time. While you are here, why don't you read some of the threads on our Baquacil section of the forum. (Until your registration is completed, you'll have to log out first to be able to see the rest of the forum.)
membership upgraded; post moved to PHMB section.
You may want to check out the info we have on using PHMB (Baquacil) successfully: http://pool9.net/phmb/
