Did I wire this correctly? just changed out my pump....
I am replacing my pool pump and just want to be sure I wired this correctly. I think my old pump was 120v and set my new pump to 120 as well. Both say they can be either 220/120.
My old pump is a pentiar superflo.
Here is the old pump with the old wiring setup and the wiring diagram from the pump.
http://i374.photobucket.com/albums/o...pscfaa8382.jpg
http://i374.photobucket.com/albums/o...ps7bac3ac3.jpg
And here is how I wired my new pump a Hayward super pump
http://i374.photobucket.com/albums/o...ps391de42d.jpg
- - - Updated - - -
on my new pump i have the white neutral to L1 and the black hot wire to L2 I assume that is correct....
Re: Did I wire this correctly? just changed out my pump....
btw i think i figured it out. the bottom picture I set it to 110 not 220. the old pump based on the pictures is set to 220.
Maybe test the voltage with a VOM? They can be had for less than $10 and are an invaluable tool for any homeowner.
Please tell me that the metal flex I see in the last photo is a TEMPORARY hookup:
http://healthybuildingscience.com/fi...01/bx-02cw.jpg
(from http://healthybuildingscience.com)
and that you are going to replace it with some type of LT conduit or UF cable!
Did you look close at the before picture? I know my electrical inspector would fail the original and the new BX.
Yeah, I saw that. But I figured that's the past. It's the present . . . and that metal flex that worries me.
