Re: Pool care for beginners
Thanks for the attaboy for PoolSolutions.
Just a heads up, though: it sounds like you might not realize that both PoolForum and PoolSolutions are mine, and that we often refer members here, to specific articles there.
ctorrent
2) Second I recommend keeping your pool clean and safe just with the typical old known Trichloroisocyanuric tablets for regular chlorination and using calcium hypochlorite for regular super chlorination shocks.
I don't think you properly read PoolSolutions if this is what you came away with. You generally do NOT want to use Trichlor tabs for regular chlorination and you do NOT need to do any super chlorination shocks if you properly maintain your pool. Instead, you generally want to use chlorinating liquid or bleach as your regular source of chlorine because unlike Trichlor it does not increase the Cyanuric Acid (CYA) level and unlike Cal-Hypo it does not increase the Calcium Hardness (CH) level. The following are facts independent of concentration of product or of pool size:
For every 10 ppm Free Chlorine (FC) added by Trichlor, it also increases CYA by 6 ppm.
For every 10 ppm FC added by Dichlor, it also increases CYA by 9 ppm.
For every 10 ppm FC added by Cal-Hypo, it also increases CH by at least 7 ppm.
Continued use of Trichlor will usually have the CYA increase over time and that makes the chlorine less effective unless you proportionately raise the FC level. So the water can turn dull/cloudy and/or have algae grow faster than chlorine can kill it. If instead you were to maintain the FC level with a constant CYA level by using chlorinating liquid or bleach, there would be no need for any weekly shocking and no need for algaecides, phosphate removers, clarifiers, flocculants, enzymes or anything else except usually a small amount of acid to maintain pH.
You can certainly use Trichlor tabs when you need to increase the CYA level or for short periods of time such as going on vacation for a week, but if you use them regularly you need to make sure the CYA isn't getting too high or need to raise your FC level proportionately. Perhaps for a short swim season with rain overflow diluting the water each winter you can get away with only Trichlor, but for most pools that is not the case.
Thanks for your quick reply. I really appreciate your comments and expertise.
Yes, I absolutely concur in that chlorinating liquid or bleach is absolutely the first choice (I’ve seen in the guidances) but I find this option really very bother to use. It causes white stains to clothes if not properly handled and it degrades over time if not properly stored. High volume is also a matter of concern because of its low concentration (about 15%). So I’ve discarded this option but I still keep a 10L bottle to use in case of unexpected incidents (fecal?).
So, don't you concur that it is possible to keep the pool clean showing crystal water during the long winter period (actually during almost 8 months that nobody swims in it) with only one Trichlor tablet (alternating with 4-effects tablets) that lasts for more than 1.5 weeks in the skimmer if monthly shocks with cal-hypo are done (the shock allows skipping the use of the Trichlor tablet for some days every month) ?. Although the chlorine level during most part of the year is really very low (< 1ppm, about 0.6 ppm) because the filter pump is running only two hours per day, nobody enters into the swimming pool during 8 months !. So water contamination is also really very low. Water temperature is also low (well below 20 ºC many weeks) and this prevents algae growing.
Of course this should be combined with frequent (weakly) cleanings of the pool to keep it free of leaves and with regular wall brushes and floor vacuums.
During bathing period on summer, chlorine is of course raised above 1 ppm but this is only for 4 months.
I estimate that at least one third of the water is thrown away in a yearly basis through vacuums, cleanings and backwashes. Maybe this is too much water, but perhaps it may allow not exceeding calcium levels of 300 mg/dl and CYAs of 70 ppm.
If cal-hypo shocks are made in a limited way it sounds to me that this allows for a big margin given that each 10 ppm of cal-hypo only adds 7 ppm CH. As pointed out before, part of the water is completely renewed in a yearly basis. Don’t you think?
Thanks for giving the opportunity to discuss this with you and for your time. You must be very busy answering questions because most pool dealers recommendations are really a complete disaster, at least here in Barcelona (Spain)
Hi and welcome!
What Richard (Chem_Geek) is trying to tell you is that your emphasis is potentially dangerous. Clear water is great, but there can still be dangerous contaminants in it.
Therefore the relationship between the Free Chlorine level and the CYA level is crucial to safety. When your CYA is 70, you need to be maintaining your FC level between 5 and 10ppm, not 1.5-3ppm. It's just not safe. Our "Best Guess Table" is really the way to go to stay safe on the relationship between FC and CYA. IF you monitor your FC levels and adjust them, you can safely maintain water with a CYA as high as 100ppm.
And, personally, I think that a higher CYA when you close for the winter isn't a bad thing as it will probably drop, but in the spring you may have a higher level than zero.
Tri-chlor tabs can be great when your CYA is low and your pH is high. They are acidic and add stabilizer. But if your pH is on the low side, and your CYA is ideal or even high, they are a bad idea.
As for your calcium levels: If you have a vinyl-lined pool, you don't really need to worry about calcium until it passes 400ppm or even 500ppm, and only then if your Total Alkalinity is in the 180-200ppm range. Beyond that you make get scaling and cloudy water. The first answer is to cloudy water (from calcium, not algae), of course, get your T/A down to the 100 range and see if it clears up. There's no reason to drain water when calcium hardness is at 300ppm. If you have a concrete, tile, plaster, etc type pool, calcium hardness should be maintained between 200 and 400 ppm, and Total Alkalinity kept under 125ppm. But, again, a calcium hardness of 300ppm is fine.
Bleach/liquid chlorine. It WILL mess up clothes if you aren't careful. But it doesn't have to. 15% concentration is higher than we get in the USA--usually the pool stuff is rated at 12.5%, but if it's fresh and new, I've tested it at 14% frequently. At higher concentrations, you need to keep it cool and dark as it WILL degrade more rapidly than lower concentrations. Ordinary laundry bleach should be available in Spain and is easy to handle. It ONLY adds FC, and doesn't affect CYA or pH. That is why we recommend it.
A final note: If you use a salt water chlorine generator (I do) your relationship between FC and CYA needs to be at least 5% (much lower than the Best Guess table) because the constant and steady infusion of chlorine into the water. So if your CYA is 70ppm, you need to keep at least 3.5ppm of FC--lower than the recommended 5-10ppm. Plus, most systems recommend a CYA of 60-80ppm.
Dear all,
I really appreciate your comments and recommendations. This is now perfectly understood. Although there is an excellent guidance on this matter on the website, I did not realize that a CYA of just 70 ppm (that I had taken as a kind of máximum level) requires a so high FC level (between 5 and 10 ppm) !!.
Regards,
C
Don't forget that a critically important part of what is taught here is understanding and taking control of your pool. That usually requires a proper test kit and we recommend the Taylor K-2006 (see this sticky post for more info). Unfortunately, you may not be able to get that in Spain. The next best kit you can probably get in Europe is the Palintest SP 315C though ideally also the Palintest FAS-DPD kit as well.
You can certainly use Trichlor or Cal-Hypo if you know what you are doing and understand the consequences. Between the two, if your CH isn't high already then Cal-Hypo may be a better choice. The downside is that you have to add chlorine to the pool every day or two since the typical outdoor pool exposed to sunlight uses around 2 ppm FC per day. Of course, this will depend on the weather in your area and also on pool temperature (some chlorine is broken down from sunlight while some is from reacting with organics in the water and with pool covers). The purpose of these sites is to give you the knowledge to be able to control your pool and not let it control you. The key is to maintain an appropriate FC level for your CYA level since that will properly disinfect the pool and prevent algae growth.
Very useful. Thanks again !!
C
