Quikchlor rp30hd auto time issue
I noticed this evening that my auto timer on my Quikchlor did not switch "ON" tonight to run. I checked the system for the current time, which is accurate and the ON1 and OFF1 times all seem to be correct as well as it being set in "AUTO" mode.
Any ideas on why the system is not switching on when its set in "AUTO" mode?
Thank you.
Re: Quikchlor rp30hd auto time issue
Hopefully, someone here is familiar with your system. Is there any kind of error code generated?
Not that I can see. Everything on the digital layout is reading how it will. The Auto arrows are showing correctly and the turn on time is showing correctly too.
