Not sure if you all remember the nightmare startup I had last year for my 1st season as a pool owner, but it was very unpleasant. (Swamp, unknown quantity of CYA converted to ammonia, 30 or 40 gal of bleach before giving up and doing a membrane divided refill, pump motor went out too, and all that after paying a pool guy $250 to open my pool.) After I finally got everything going the rest of the season was smooth sailing. Closed the pool myself and followed all advice here. Thanks to all of the excellent info and support, I uncovered my pool to mostly clear water, nearly perfect chem levels (7.0 fc, and cya held constant at 50). Despite the extreme winter this year's opening is going great. I will be raising the water level and getting the pump going Saturday, so we will see how good a job of closing I did on the equipment then. So far the only problem has been that our autocover ripped as I was getting leaves off of it... Expensive to replace but it was visibly old so there was no surprise when it gave out. Just wanted to share how helpful the people here are. Although I lurk red around on the forum a few times this winter, it's good to be back in full swing here. Happy spring!
