I have a Pool cartridge that has to be cleaned, rather than just rinsing it off.
What kind of solvent do I use?
Thanks, RTonk
Thanks, RTonk
TSP works the best for me but it can be hard to find the real stuff anymore. They have a substitute now that is more environmentally friendly but like most things, it doesn't work very well.
A lot of people used to soak them in electric dishwasher detergent.
If you have access to a pressure washer, try pressure washing it
I would avoid a powered pressure washer. A standard hose with a nozzle is fine but most pressure washers have enough power to easily tear the fabric in a cartridge filter.
Here are the instructions you need:
Cleaning-your-Cartridge-Filter-without-Damaging-It!
Using a pressure washer can destroy cartridges instantly. Here are some 2013 pics of cartridges at a local fitness center that had been pressure washed:
https://lh6.googleusercontent.com/-K...0/IMGP0724.jpg
https://lh3.googleusercontent.com/-M...0/IMGP0725.jpg
https://lh6.googleusercontent.com/-E...724-detail.jpg
These were very expensive StaRite System3 cartridges. They had multiple filters, and had to spend over $2,000 buying a single new set for all filters.
No, I would NEVER pressure-wash a cartridge. Better to soak it in a container with electric dishwasher detergent then rinse it with a hose.
My rather small pressure washer can easily strip paint and even splinter wood surfaces if held too close.
