Can I use an Intex sf5110 pump & filter with my new Trevi 27' round pool?
I am purchasing a Trevi 217 krystal above ground pool 27' and 52" deep-- can i use my Krystal clear sand pump 14" model sf15110 and my krystal salt water system Model cs8110 with this pool or are they not large enough for this pool. this is my first pool that is not an intex. any help will be great thanks maggy
Re: what will work with my new pool
The Intex pump and filter you have are too small for a 27' round pool (approx 16,000 gallons). In fact, they are actually undersized for the Intex pools they are usually sold with. If anyone actually swims in your pool, it will rarely if ever be clear using that filter.
Sorry
(welcome to the forum, though!)
Your pool is between 17,000 and 18,500 gallons (depending on whether the WATER depth is 48" or 52"). You're going to need a bigger pump and filter, on the order of 1/2 to 3/4 hp with a filter to match.
