New pump, or just new motor?
I have a Dura Glas 1 1/2 HP pump that I believe is 20 years old. It is shot, so the question is, do I replace the whole pump/filter unit? Has there been efficiencies in design that are worth it, or should I just replace the motor. I have taken the pump apart and the impeller appears to be solid, as does the the rest of the filter portion of the pump.
I also have a question on the 2 phase pumps/motors as that appears to be the way to go. How do these exactly work? Is there a 3 way type switch that needs to be installed, off, low, and high? Thanks, and I look forward to your insight.
