Replacing LED Pool Lights
We purchased our home two years ago and it had a salt water pool with multi-color LED lights. The pool is 4 years old. The lights quit working in the pool but not in the hot tub about 6 months ago which seems a short time. I am now searching for a replacement light. I got a supply and an install price of $850. I wanted to get an opinion on the best light to buy. Most of the one s I have seen are running $450 to $625 for the light. Any help would be welcomed.
david76houston
Re: Replacing LED Pool Lights
membership updated . . .
I'm not sure what sort of system you have now -- if you want better advice, you'll need to provide make, model, and voltage of your existing system.
If you happen to have conventional niche with a 12V feed, this may be a cheaper option for you:252 LED 12 Volt Color Changing Replacement Swimming Pool Light Bulb
As far as replacement labor, again, it's hard to offer an opinion without more info. If your system can be fixed simply by dropping in a new LED unit, $850 might be high-ish, though it depends on the market.
But if the conduit from the junction box to the niche is in poor condition (common!) and the lamp cord is not free . . . $850 might be a real bargain. Likewise, if new wiring (and electrician service call) is required.
Good luck.
