Getting started with the "BBB"
I have a 6,000 gallon fiberglass pool. After spending a fortune on shock, shock and more shock and then being told I need more shock I started looking around on the net! Found this site and the first thing I did was order a Taylor K2006 test kit!. Now I want to get started on using the 3 Bs to get this pool dialed in! I went and picked up some regular bleach and so far I have held a chlorine level above zero for 2 says in a row! I just need to know where to start exactly?
Re: Getting started with the "BBB"
If you have your K2006, post your full test results. A description of what your water looks like can be helpful, too.
Also, read a lot on the forum, especially the stickied threads at the top of many of the subsections. I would also suggest reading on our sister website www.poolsolutions.com.
Glad to have you join us!
Read, Read, Read! Then you'll find it's easy!
