Trouble
Have an inground pool. Temp. have been around 102 degrees i.e. "HOT", continue to add Chlorine and algecide. Pool continues to turn green even after I vacuum the green algae to waste (Sand Filter sys.). I have not added a stabilizer. Could this be the problem?
Re: Trouble
You will need to post a current set of water testing results taken with a drops-based kit (no test strips) for someone to be able to help. Also, tell what all you have put in the pool meaning ingredients and not just 'shock' and give the volume of the pool.
Welcome to the Pool Forum!
