What kind of patch should I use? Never patched before and want to make sure I get the right kind.
I found some 25 gauge patch kits on Amazon. They sell them in multiple patterns and one matched mine. But it did not match the area below the beaded hanger. It has a tile design, not shimmering water design. Basically, you cut a good size patch to cover the area and then some, round the corners on your patch. Spread vinyl glue evenly over the patch. I like to put the patch on the water side. Press it on, don't worry about it getting wet, it will still hold. Hold it there for 15 minutes.
Thanks for the info!
