Pool was blue cloudy unable to see shallow end or deep end but blue. Meaning I was greenless in the pool. Then I added bleach to pool and now I am green again. Bleach = green pool what gives???
What is your source of fill water? Sounds like it might be a metals issue.
What are your chlorine & pH levels?
What is your CYA level?
What pump and filter do you have? Is the pump on 24/7?
What chemicals have you been using regularly?
If you have a vinyl or FG pool, do the sides feel slimy?
. . . and . . .
As Watermom asked, where is your water coming from?
