Picture of S 244T Hayward Valve Control?
Almost finished installing used pump and filter but just realized the plastic sticker on top for valve control positions is missing.
Does anyone have a pic of the top as I'm not sure if I'm recycling or filtering etc.
It is a 6 position Valve control (black), not sure exact model.
Thank you in advance.
Re: Picture of S 244T Hayward Valve Control?
Have the same filter and the valve is a SP-711. No pic but looking down on the valve the positions are as follows going clockwise:
Filter-Waste-Closed-Backwash-Recirculate-Rinse.
The Filter position is directly over the gauge port.
Hope this helps.
1 Attachment(s)
So this is in the filter position?
I have the SP714, and where you have it is filter on mine.
Thanks guys, the reason for the posting (kinda cross-posting sorry) is that I was getting paranoid I wasn't filtering as the pool although crystal clear showed alot of small debris once I went underwater with goggles on. I'd thought running the "overkill" pump and filter for 4 hours in a 5500 gallon AG pool would eliminate all debris.
I may backwash today just to look, and might open her up for a quick peek.
Replaced the guage and took the top off to take a look.
Kinda funny since I have no idea what it should look like!
Anyways, there was around 6 inches of clear water and I could see some debris on top of the sand.
Put my hand in a felt the sand (again, no idea why) , it felt like... wet sand and soft enough to poke in.
So...I won't bug anymore, does this sound like a finely tuned working pump?
Oh, with pump on the guage reads 10 and off reads 0...
