Re: Nefretrameses: HI2C pool
You're not really in the HiC2 range, with a CYA=70. That is RECOMMENDED levels for an SWCG, and is an acceptable level generally.
The only real adjustment needed is to be use a Taylor pH test; using non-Taylor test with FC=18 can result in bogus readings as the phenol red indicator is converted to chlorophenol red, a DIFFERENT reagent.
Of course, at any level of CYA > 30 ppm, you need to follow the Best Guess chlorine levels, not the one in the Taylor book, or any other book.
