New 12' x 3' Intex pool in Texas
Wish I had found this forum sooner. Live 30 miles NW of Fort Worth. Set up a new Intex metal frame 12' x 30" pool 2 weeks ago. We filled with well water (filtered). Water is clean and clear. I have been using test strips and water testing at the pool store (closest store is 20 miles away). I posted the last test results (from the pool store) using the "Pool Chart Entry Form". They indicated that the Total Alkalinity is high and recommended adding 3 ounces of dry acid to the pool. Have done that 3 days in a row, but the test strips are still showing TA reading high. Question 1: suggestion for lowering the Total Alkalinity. Question 2: I have some Leslies ChlorBrite. How many ounces would you recommend in order to shock this pool (1700 gallons)? Thanks for the help.
BTW: After reading the forums I know I need to get a new test kit.
