Poolsean
cody, do you have an automatic cover on the pool? If so, then you will need a system that you can fine tune so as not to overchlorinate. If not, then as Ben mentioned, you'll need to consider the pump run time and actual pool usage. I normally recommend to get the largest size cell you can afford. In this case, again as Ben mentioned, make sure the system you select gives you enough control over the output. For instance, if the output is controlled by LED lights, a system with 5 lights on the output levels will give you 20% increments. 8 LED lights = 12.5% increments, etc... Digital displayed units should give you 0 - 100% control in 1% increments.
