Hi, I have an Aqua Comfort model 125 heater. The display says the water temperature is 129 degrees, which is way higher than it actually is. I can only set the thermostat to 95 degrees so I can not test if it will work.
Has anyone had this problem, and if so how did you solve it? I am suspecting the temperature sensor is faulty. If anyone has a line on where to find Aqua Comfort parts please let me know.
