Re: First time pool owner
Zack, we don't trust those test strips. Do yourself a favor, and go ahead and order a Taylor K-2006. You won't regret it.
You can use trichlor tabs to bring your CYA up and then switch when you get it where you want it but if you do so, you're going to have to be able to measure CYA. Test strips are notoriously inaccurate especially on the CYA test. Also, trichlor is very acidic and will drive your pH down, so you will need to monitor it closely.
While you are waiting for your registration to be completed, if you log out, you can see the rest of the forum and use the search. But, don't use the search feature that is built in to the forum software. Use the one in one of our signatures or you can go to www.poolsolutions.com and find the search there as well.
Welcome to the Pool Forum!
