Having trouble clearing up my water this year. It stays cloudy no matter the chlorine level, currently 5 ppm. Pool store test showed low ph and alkalinity. I put in the necessary all adjuster, waited 2 hours and then adjusted the ph, now reading in the ideal range. The water was still cloudy when I left for work 2 hours later. Normal? If so, when should I see some change?
